95 Ram rough idle
Old Jan 8, 2006 | 05:07 PM
modaddyoh's Avatar
modaddyoh
Default 95 Ram rough idle
Having problems with a 95 Ram 1500 2 wheel drive. Fault codes i'm getting are 12 and 55. The truck will run fine for 20 minutes on intial start up and then spit and sputter until it is unable to pull it's on weight. The motor has been recently tuned up dist.cap, wire's, plug's, etc. to cure the problem and that didn't help. Replaced oxygen sensor that didn't help. It does have 220,000 any suggestion's on what it could be. I have taken it to the dealer 3 times and they can't tell me what's wrong with. Once it shut's down and I wait for a bout 15 minutes it's start's up and run's like nothing is wrong with it. I'm stumped and need help. Thanks.
Old Jan 9, 2006 | 05:55 AM
Chump's Avatar
Chump
Default RE: 95 Ram rough idle
ORIGINAL: modaddyoh
Quick guess is that the fuel pump is starting to die. Time for a fuel pressure test when it acts up. Might be a bad Crank Postition sensor or it's connector.
Old Jan 20, 2006 | 12:36 PM
Junior5290's Avatar
Junior5290
Check fuel pressure, if ok when condition is present, does your tach read any rpms? possibly a crank sensor issue. When the sensor warms up it becomes fuzzy and wont be able to fire.
