auxially lights
Old Jan 20, 2006 | 07:30 PM
lance49726's Avatar
lance49726
Default auxially lights
I have a 96 dodge ram and have a pair of auxially fog lights hooked up to the back of the headlight switch so they come on when i turn the running lights on so i can have them on all the time.
My ? is i have a pair of auxially high beam lights that i want to be able to turn on when i switch the high beams on in truck and shut off when i switch to low beams which colored wire do i need to connect to below the steering column that comes off or goes to the high/low beam switch in truck. Thanks
Old Jan 21, 2006 | 08:28 PM
lance49726's Avatar
lance49726
Default RE: auxially lights
I hooked up the auxially high beam lights with a wire from #85 off the relay to the back of the trucks headlamps red wire high beams and the lights come on when i turn the high beams on but will not shut the lights off when i switch to the low beams any help would be appreciated. thank you
Old Jan 23, 2006 | 09:56 PM
lance49726's Avatar
lance49726
Problem fixed it was a wiring harness adapter that went to the headlights from the snowplow.
Old Jan 25, 2006 | 09:20 PM
casper's Avatar
casper
Not bad you helped yourself, lol
