P0320 code
My 2000 Durango has been showing code P0320 several times. This seems to be an intermittent problem (about every 3-4 days) and then works fine again. Vehicle doesn't want to start and then it will start by giving a little bit of gas. I have heard that some possible solutions are to replace the crankshaft sensor or the throttle position sensor. Can anyone give me a sepcific thing to try. I don't want to play trial and error by replacing a bunch of sensors if it is not needed.
P0320 - Ignition/Distributor Engine Speed Input Circuit
That is the only code that it set. Is there any way to pinpoint the problem to one thing or is it just a trial and error deal. Also, do you know where the crank sensor is located? Is it easy to change? I can pick one of those up for about $25 so I think that it would be a cheap place to start if it's easy to change.
