HELP PLEASE!!! Tranny trouble
Old Jan 27, 2006 | 11:06 PM
Jeanette656's Avatar
Jeanette656
Default HELP PLEASE!!! Tranny trouble
I Just got a 96 neon sport yesterday, a new tranny was installed, now there is about 5 inchs of play on the clutch, I basically have to push it through the floor to get it to shift, if i let the clutch up even a half an inch it takes off. I was told its a self adjusting clutch......So now what?? No one seems to know.....Please help!!!
Old Jan 29, 2006 | 02:06 AM
kdh97602's Avatar
kdh97602
Default RE: HELP PLEASE!!! Tranny trouble
self adjusting, yes - but its also hydraulic - probably needs to be blead like a set of brakes. don't know about the neon's, but a chilton or hays manual should tell you where to start. if not, check reputable brake shops to blead the system for you.
good luck
Old Jan 30, 2006 | 03:05 AM
06ChargerSXT's Avatar
06ChargerSXT
Try THIS
Push the clutch all the way to the floor then
slide your foot off to the right causing the clutch to
snap back try this a couple of times.
