Koltz Octane Booster??
Old Feb 2, 2006 | 11:43 AM
FSTSRT4's Avatar
FSTSRT4
Default Koltz Octane Booster??
Has anyone heard of this???
Klotz is the leader and innovator in producing Octane Boosters and still the front runner in actual numbers of octane increased per ounce and cost effectiveness. Klotz Octane Booster provides extra strength in building octane and upper cylinder lubrication. One ounce per gallon of gasoline will raise the octane 2-1/2 numbers. Proper octane level helps eliminate pre-ignition and detonation, allowing engine to run cooler and to its fullest potential.
Klotz Octane Booster is environmentally safe and provides lubrication benefits equal to tetraethyl lead. Formulated to increase octane ratings of leaded or unleaded gasoline by 10 numbers or more if desired. Klotz Octane Booster is designed as a legal additive in all types of stock class racing. Adding more Octane Booster to gasoline than needed is not necessarily harmful, but simply becomes non-effective past a certain point. No more than 120 total octane can be achieved with gasoline as a fuel by nature. Using a significantly higher octane content than required can actually reduce power, as the effect of the slow burning fuel produces less combustion pressure. Klotz Octane Booster is also an excellent gasoline stabilizer preserving gasoline up to 16 months during storage.
Tests indicate the yield these added benefits...
* 1 oz. per gallon raises octane 2-1/2 numbers - 2 to 3 oz. per gallon produces significantly racy exhaust odor.
* Helps stop pre-ignition & detonation -Absorbs water condensation
* Helps stop engine run on & Cleans Fuel injectors
* Allows higher compression ratios & increases throttle response
* Provides upper cylinder lubrication equal to lead
* Preserves gasoline in fuel tank up to 16 months
PERFORMANCE APPLICATION DIRECTIONS: One ounce per gallon will raise the octane 2.5 numbers, for racing add 3oz. per gal. of fuel. (Octane can be raised 10 numbers or more if desired). Experiment by trial and error to find the most suitable combination. To help eliminate varnish build-up in carburetor and fuel systems on a regular day to day basis, add one ounce to two gallons of gas periodically. Klotz Octane Booster has extra strength which makes it very effective & because of this it must be packaged in metal containers to maintain its strength. WARNING: DO NOT mix with Nitromethane, a violent reaction or explosion will occur. However, this product CAN be used with the Klotz NITRO Propanol additive as shown above.
STORAGE APPLICATION DIRECTIONS: Add one ounce per gallon to preserve gasoline from 6-8 months. Or two ounces per gallon for 12-16 months storage.
Flash point 125 degrees
