Battery drain
Old Mar 19, 2006 | 03:23 AM
cocoa's Avatar
cocoa
Default Battery drain
Need some help. I have a 97 intrepid. I started to encounter some battery drainage problem, over night or sometime over two nights the battery is completely drained. I did a current (amps) check with the car not running and from out there was a continuing draw of .6 amps. One of my check was removing the ABS fuse and there is where found the current draw was coming from. I brought myself a repair manual but no wiring diagram of the ABS system was included. Anyone came across this problem and is there suggestions. If someone have the ABS wiring diagram, I'll really appreciate it.
Thanks
