Igniton Module asistance...
Old Mar 22, 2006 | 12:04 AM
Shadowboy's Avatar
Shadowboy
Default Igniton Module asistance...
okay, so i got this dodge colt vista wagon right. Its a 92 with an engine for a 93. I had a no start situation, but it was only half of the time. It would start run till it got hot and then cut out. So i inspected the ignition system, fuel diliver system and the air intake system. All seemed to be working fine. So i decided to do a tune up as it needed one anyway. After that was finished, it ran a lot better but still cut out once it got warm. So after sitting down and thinking for a bit i realized that an ignition module would be the cause of that if it was worn and got hot enough to break contact. So currently i am looking for a new ignition module to see if i am correct, which i most likey am [sm=shades.gif]...
but my problem is locating a place that will see this part to me. Lordco doesn't have it, Napa is useless, Chrysler dealerships can *beep beep beep* a fat *beep beep* cause they want to sell me the whole distributor setup and not any part inside for $1300 *beeping* dollars... I also refuse auto reckers as they will just rip me off like dealerships do. I need this situation rectified ASAP cause i need it to get to work and if not i will be evem more *beeping beeped* off than normal...
Thank you for all help
Most appreciated...
Old Mar 24, 2006 | 05:29 AM
Shadowboy's Avatar
Shadowboy
Default RE: Igniton Module asistance...
Problem solved...
I rule, as suspected.
