Thermostat
Old Mar 22, 2006 | 01:07 AM
citygasdude's Avatar
citygasdude
Default Thermostat
Would someone please explain what changing to a lower temp thermostat actually does for you engine. I see several postings that talk about this but they dont explain what the benifit is. Please forgive my lack of knowledge in advance.
[IMG]local://upfiles/31643/E6B9FB7C38CF435CA8ECAEF6F3755877.jpg[/IMG]
Old Apr 2, 2006 | 05:18 PM
rambob's Avatar
rambob
Default RE: Thermostat
The idea is it helps your engine run cooler which in turn helps keep combustion chamber temps lower and intake tems lower which helps with a cooler denser intake charge and prevents the computer from retarding ignition because of knock. On a stock engine with a factory program in the computer it won't do anything, it may screw up your engine by cooling the engine to the point the pcm won't go closed loop, your engine will run rich and your milage will suffer.
