rough idle when weather is warm????????
Old Mar 27, 2006 | 09:10 PM
shorty9166's Avatar
shorty9166
Default rough idle when weather is warm????????
have a 89 b150. 220,000 miles. when the weather is hot, weather the vehicle is warm or cold, the engine spits and sputters for about 45 seconds when started. then it all smooths out. also the vehicle hesitates when you press on the gas, this happens regularly... any information?????????
Old Mar 28, 2006 | 12:36 AM
Kitulu's Avatar
Kitulu
Default RE: rough idle when weather is warm????????
if it has a carburetor, the accellerator pump could be clogged..it happened on my 76 toyota once.
Old Mar 30, 2006 | 11:43 PM
Chump's Avatar
Chump
ORIGINAL: shorty9166
It's fuel injected and I would think you have a bad fuel pump. Have you done a complete tuneup to it and replaced all the filters. Could also be a bad TPS sensor or Coolant Temperature Sensor.
Try this, the next time it is warm and you try to start it. Turn the key to "ON" for a few seconds, then "off", do this 3 or 4 times and then try to start it as normal. If it starts up right away and runs better, you have a fuel problem, most likely the pump.
