Power Outlet fuse
Old May 4, 2006 | 07:44 PM
epsails's Avatar
epsails
Default Power Outlet fuse
I have a 2000 Durango and need to know where the fuse is for the 12 volt power outlet on the dash. This is the one that is on all the time, not the cigerette lighter that is only powered when the ignition is on.
Thanks
Old May 5, 2006 | 02:51 AM
epsails's Avatar
epsails
Default RE: Power Outlet fuse- I found it!
I found the fuse. You have to look up under the dash on the left side. There are 4 more fuses on the back side of the regular fuse panel. They aren't listed in the owner's manual, and I don't know what the other 3 do, but the 20 amp fuse is for the power outlets. The other 3 may be for other things that have power to them all the time too.
