After finding TSB, then where ?
Old May 8, 2006 | 10:22 PM
PartyOnWayne's Avatar
PartyOnWayne
Default After finding TSB, then where ?
Hi, I'm new to this forum. After I find a TSB, where do I find the steps to fix the problem?
Thanks.
Old May 9, 2006 | 08:20 PM
buckw1's Avatar
buckw1
Default RE: After finding TSB, then where ?
Whats the TSB? ALLdataDIY to buy cd/dvd repair manual for one make/model of car.
Buck
Old May 10, 2006 | 04:10 PM
PartyOnWayne
ORIGINAL: buckw1
Buck
Want to know about TSB 0200401 suspension, and TSB 083198 wipers. Both for a '97 Caravan ES.
Thanks
Old May 10, 2006 | 06:01 PM
buckw1's Avatar
buckw1
TSB 0200401
DATE: July 6, 2001
SUBJECT:
Knock/Squawk Sound From Front Suspension
OVERVIEW:
This bulletin involves installing new front sway bar link assemblies.
MODELS:
1996 - 2000 (NS) Town & Country/Caravan/Voyager
1996 - 2000 (GS) Chrysler Voyager (International Markets)
2001 (RS) Town & Country/Caravan/Voyager
2001 (RG) Chrysler Voyager (International Markets)
SYMPTOM/CONDITION:
1. A squawk/creak/groan sound is heard when turning the steering wheel at a stop or during a low speed turn such as a parking lot maneuver.
2. A knocking/clunking sound is heard from the front suspension while driving over rough/bumpy roads.
DIAGNOSIS:
1. With a helper in the vehicle, apply the parking brake, start the engine and turn the steering wheel in both directions. Reach between the top of the front tire and the wheel well lip and grasp the sway bar link. Listen or feel for the condition described above while the wheel is being turned. If the condition is present, perform the Repair Procedure.
2. Drive the vehicle over rough/bumpy roads to verify condition. Raise the vehicle on an appropriate hoist and perform a visual inspection of the front suspension. Repair or replace any loose, damaged or worn components and test drive vehicle. It the condition is still present, perform the Repair Procedure.
REPAIR PROCEDURE:
1. Raise the vehicle on a frame contact hoist.
2. Remove both front wheels.
3. Remove the upper and lower sway bar link nuts and remove the sway bar link.
CAUTION :WHEN INSTALLING THE NUTS TO THE STUDS OF THE SWAY BAR LINKS, DO NOT ALLOW THE STUD TO ROTATE IN ITS SOCKET. HOLD THE STUD FROM ROTATING BY INSERTING A # 40 TORX BIT INTO THE END OF THE STUD.
4. Install the new sway bar link. Install the sway bar link nuts and torque to 88 N.m (65 ft. lbs.).
5. Perform steps 3 and 4 for the other sway bar link.
6. Install both front wheels, use a criss-cross pattern to tighten the lug nuts to 70 N.m (50 ft. lbs.) and then use a criss-cross pattern again to tighten to a final torque of 135 N.m (100 ft. lbs.).
7. Lower vehicle.
and the other
NO: 08-31-98 Rev. A
GROUP: Electrical
DATE: Jul. 24, 1998
SUBJECT:
Front Windshield Wipers Self-Activate While Driving Or Will Not Turn Off
NOTE :THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-31-98, DATED JUNE 26, 1998, WHICH SHOULD BE REMOVED FROM YOUR FILES. THE REVISIONS INCLUDE, REVISED SYMPTOM/CONDITION ONE, DIAGNOSIS AND REPAIR PROCEDURES FOR SYMPTOM TWO AND THREE, AND PARTS REQUIRED. REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS**.
MODELS:
1996-1997 (NS) Town & Country/Caravan/Voyager
1996-1997 (GS) Chrysler Voyager (International Markets)
SYMPTOM/CONDITION:
1. Windshield wipers will turn on while the windshield wiper switch is in the "OFF" position for one or more wipes **with the ignition "ON",** or when the turn signal and/or headlamp beam select is actuated.
2. Windshield wipers will not turn off with the ignition switch "ON" or OFF and the 4lTE transaxle may go into limp-in mode when the windshield wipers are turned "ON".
3. Windshield wipers stop immediately (instead of parking fully down) when the switch is turned "OFF" or continue to wipe for approximately 10 seconds after being turned "OFF" and then stop wherever they are (instead of parking fully down) either by using the windshield wiper switch or the ignition switch.
NOTE :IF THE WIPE OCCURS AT VEHICLE START UP ONLY, MAKE SURE THE IGNITION OFF DRAW (IOD) FUSE IS FULLY SEATED.
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No:
08-80-87-93 Replace Multi-function Switch 0.4 Hrs.
08-89-01-92 Replace PDC 0.4 Hrs.
08-52-80-91 Replace Wiper Motor 0.9 Hrs.
FAILURE CODE: P8 - New Part
Note that dealer parts inventory will carry only the latest revision of parts mentioned.
Old May 10, 2006 | 08:10 PM
PartyOnWayne
Thanks Buck, that helps alot.
