engine swap
96 dodge what?
I'll assume Ram
yes it should fit, (measure twice, cut once) the mounts would be different tho
yes, the wiring would be absolutly different but if you get the wiring from the new one you could swap it out which would be better to do anyway...
I'll assume Ram
ORIGINAL: buckw1
Get the wiring harness and computer fromn the newer vehicle.
Buck
Buck
What motor are you trying to take from an 04 Ram? The 5.9L 360? I hope so. The 4.7 and 5.7 wouldn't be easy swaps at all...and in NO way direct. The 5.9 would be the only direct motor swap. Just put the new motor in, and use the sensors/harness/computer from a 96 5.9L. You shouldn't have any issues doing it that way.
