'95 Avenger bulb replacement location in center console
Old May 31, 2006 | 03:20 PM
gwurzinger's Avatar
gwurzinger
Default '95 Avenger bulb replacement location in center console
This is my first posting.
Where is the location of the bulb for the Park, reverse,Neutral, and Drive lens in the center console of a '95 Dodge Avenger? My is burned out.
Can't find the information in the owners manual.
Thanks,
Gary
Old May 31, 2006 | 08:00 PM
yakkier's Avatar
yakkier
Default RE: '95 Avenger bulb replacement location in center console
Not sure right off hand but if you goto autozone or advanced they have service manuals that'll give u the exploded version of your car an you should be able to track it down from there, there's usually just a VERY tiny blub in there that's easy to replace, all else fails take your console appart an find it an replace it dont be afraid to get your hands dirty my friend!
Old Jun 1, 2006 | 11:07 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You will have to remove the center console and the shifter bezel to get to that bulb, it's the same bulb as the one that lights the ashtray #74.
Outside Front
Low Headlights 9006
High Headlights 9005
Fog Lights H3-55w
Front Turn Signals 1156
Headlight Sidemarker 168
Outside Rear
Brake Lights 2057
Rear Turn Signals 2057
Rear Parking Lights 194 *
Back Up Lights 1156
Third Brake Light 921
License Plate Bulbs 194
Inside
Dash Floor 194
Dome DE3175
Rear Floor / Courtesy 561 **
Glove Box 194
Step 74
Gauge Cluster 37, 74, 194
HVAC 37, 74, 194
Ignition 74
Lighter 74
Ash Tray 74
Shift Indicator 74
Trunk DE3022
Rearview mirror 214-2
