slant 6 surging
Old Jun 2, 2006 | 12:23 AM
ct1979's Avatar
ct1979
Default slant 6 surging
I have a 84 dodge diplomat with a slant 6. It has 44k miles on it. The engine surges at idle after it warms up and also has a miss. Plugs, wires, distributer cap and rotor are new, I replaced some vacuum lines and haven't noticed anymore vacuum leaks. I checked the egr valve and it looks fine. The carb, fuel filter and fuel pump are brand new. I checked for slack in the timing chain too. This car had sat for a long time, and I dont know what else to try. Any help or ideas is appreciated. Thanks in advance, Jay
Old Jun 2, 2006 | 02:14 AM
buckw1's Avatar
buckw1
Default RE: slant 6 surging
A V8 transplant?
Old Jun 5, 2006 | 01:08 PM
chopper's Avatar
chopper
Make sure the fuel tank vents aren't plugged.Try driving it with the fuel cap loose to see if it makes a difference.The ignition module could be going bad and could cause your problem.
