99 Cummins 5 speed hard to et into gear?
Old Jun 28, 2006 | 11:07 AM
darylkey's Avatar
darylkey
Default 99 Cummins 5 speed hard to et into gear?
It's like the clutch isn't releasing all the way. I've pulled the floor mat and same thing happens. It comes out of gear fine, but won't go in easily. This has just happened and came on pretty quick.
Thanks for any help.
Old Jun 30, 2006 | 04:14 PM
shadowzform's Avatar
shadowzform
Default RE: 99 Cummins 5 speed hard to et into gear?
try tightening your clutch cable and see if that helps. there's a way you can adjust it. Find out.
Old Jul 1, 2006 | 04:34 AM
The Burning Rom's Avatar
The Burning Rom
You may be having this problem....it's common: http://dodgeram.info/tsb/1998/21-10-98a.htm
