heater/ac blower not working
Old Jul 9, 2006 | 03:10 PM
drjgarage's Avatar
drjgarage
Default heater/ac blower not working
2003 Dodge Dakota, blower doesn't work. Went to turn it on and it doesn't work. I checked the fuse. Any other thing that it could be before I go to dealer or pull the motor??? Any help is great help!!![:@] If there is a resistor where would I find it? I read some other posts and the resistor is mentioned alot. Can't find it. HELP AGAIN!!!!
Old Jul 9, 2006 | 07:31 PM
thump186's Avatar
thump186
Default RE: heater/ac blower not working
Chances are it is the control unit itself. There is a resistor for the motor and i belive it is contained in the heater control unit. As a matter of fact i had mine replaced under warranty and now it is doing the same thing nothing but high. Chances are it is the heater controls.
Old Jul 18, 2006 | 05:42 PM
drjgarage's Avatar
drjgarage
Well I took it to the dealer and it was the resistor. As I asked before where the heck is it????? It was a $10 part. Luckly it was under warranty. I would like to know for future use. Please help!!!!1
Old Jul 18, 2006 | 09:09 PM
dodgerules86's Avatar
dodgerules86
It is "mounted to the HVAC unit inside the passenger compartment. It can be accessed from the passenger foot well area."
Old Jul 28, 2006 | 04:27 PM
cleverusername's Avatar
cleverusername
thats kinda funny, mine just went out yesterday. like dodgerules said, its on the passenger side in the foot well area. when you look up you'll see the blower motor and 2 connections. 1 is for the blower its just a 2 pin connector. the other is a 5 pin connector. disconnect that and unscrew the 2 hex screws on the side, it will fall right into your hand. thats it. 5min. hope it helps.
