engine quits
I have a 86 dodge ramcharger and when i start it i have to hold the key over to start and it will run but when i let off it quits. I changed the ballast resistor and it did not help. Does anyone know what it might be?
Thanks for your help.
Stewart
Stewart
It could be the Ignition switch itself..... If you have a schematic there is a "Start" wire that's only "hot" when the key is turned all the way to start
and there's a "Run" wire that's only "hot" when the key turned to run
