Replace the fuel pump WITHOUT dropping the tank
Most Dodge pick-ups and one time or another need a new Fuel Pump
Basic hand tools and less than an hour of your time is all you need to replace your In Tank fuel pump even if you have a FULL tank!!!
Remove the 3 screws around the gas cap first
there is 8 bolts that hold the bed on..... take the front 6 out and loosen the 2 at the very back of your bed
jack up the front of the BED or have a couple strong friends lift it high enough to get a jackstand under the bed.... There's PLENTY of room to remove/install a pump without draining and removing your Tank.
