SRT-4/Neon 3D Taillights Install Part II
Use a 13 mm wrench to loosen the three PLASTIC nuts holding the lens in place. The lens will pull out to the rear of the car. (First picture)
Unscrew the bulbs counterclock wise to remove from the housing. Note the red locking "button" on each light and the "key" on the shoulder of the sockets. (2nd Picture)
Reverse the procedure, screwing the bulbs in clockwise, making sure to line up the points of the "key" on the bulb socket to the lens socket holder. Hint: Remove the larger bulb first, and replace it last. Tighten PLASTIC nuts down to the point where they do not move under mild torque. (3rd Picture)
ENJOY!!!!
[IMG]local://upfiles/894/Ca814198286.jpg[/IMG]
[IMG]local://upfiles/894/Ni226100623.jpg[/IMG]
[IMG]local://upfiles/894/Io291346377.jpg[/IMG]
ENJOY!!!!
