Myths about synthetic oils
Old Dec 4, 2003 | 09:51 PM
SyntheticsMan's Avatar
SyntheticsMan
Default Myths about synthetic oils
Ten Myths About Synthetic Lubrication
First Published in National Oil and Lube News by Ed Newman
It's a fact of life that behavior is strongly influenced by what people believe, whether true or not. Numerous examples from history bear this out. For example, sailors were once fearful of sailing outside the sight of land less they would fall off the edge of the world. In the early 19th century, the train was considered dangerous because it was believed that if you traveled faster than 25 miles per hour, you would be traveling too fast to breathe. At a later date, the New York Times warned that electric light may cause blindness. Microwave ovens, automobiles and airplanes have had equally vociferous opponents.
Looking back, it is easy to laugh at some of these things people so firmly believed. But these people were not stupid. They were simply misinformed. In many instances they had simply drawn conclusions before all the facts were in. How easy it is to make the same mistake today. In our own time, synthetic motor oils have been the object of many misconceptions held by the general public. Many people, including some mechanics who ought to know better, have been misled by persistent myths that need to be addressed.
PARAMETERS OF THE DEBATE
Synthetic lubricants are fuel efficient, extended life lubricants manufactured from select basestocks and special purpose additives. In contrast to petroleum oils which are pumped from the earth and refined, synthetics are custom-designed in the laboratory, with each phase of their molecular construction programmed to produce, in effect, the ideal lubricant.
In responding to objections most commonly raised against synthetics it is important to establish the parameters of the debate. When speaking of synthetic motor oils, this article is defending the synthetic lubricants which have been formulated to meet the performance standards set by the American Petroleum Institute (API). (The first such synthetic motor oil to meet these industry-accepted tests for defining engine oil properties and performance characteristics was AMSOIL 100% Synthetic 10W-40 in 1972.)
Many people with questions about synthetics haven't known where to turn to get correct information. Is it super oil or snake oil? Some enthusiasts will swear that synthetics are capable of raising your specialty car from the dead. On the other hand, the next fellow asserts that synthetics will send your beloved car to an early grave. Where's the truth in all this?
In an effort to set the record straight, we've assembled ten of the more persistent myths about synthetic motor oils to see how they stack up against the facts.
Myth #1: Synthetic motor oils damage seals.
Untrue. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
Myth #2: Synthetics are too thin to stay in the engine.
Untrue. In order for a lubricant to be classified in any SAE grade (10W-30, 10W-40, etc) it has to meet certain guidelines with regard to viscosity ("thickness").
For example, it makes no difference whether it is 10W-40 petroleum or 10W-40 synthetic, at -25 degrees centigrade (-13F) and 100 degrees centigrade (212 degrees F) that oil has to maintain a standardized viscosity or it can't be rated a 10W-40.
Myth #3: Synthetics cause cars to use more oil.
Untrue. Synthetic motor oils are intended to use in mechanically sound engines, that is, engines that don't leak. In such engines oil consumption will actually be reduced. First, because of the lower volatility of synlubes. Second, because of the better sealing characteristics between piston rings and cylinder walls. And finally, because of the superior oxidation stability (i.e. resistance of synthetics against reacting with oxygen at high temperatures.)
Myth #4: Synthetic lubricants are not compatible with petroleum.
Untrue. The synthesized hydrocarbons, polyalphaolefins, diesters and other materials that form the base stocks of high quality name brand synthetics are fully compatible with petroleum oils. In the old days, some companies used untested ingredients that were not compatible, causing quality synlubes to suffer a bum rap. Fortunately, those days are long gone.
Compatibility is something to keep in mind, however, whether using petroleum oils or synthetics. It is usually best to use the same oil for topping off that you have been running in the engine. That is, it is preferable to not mix your oils, even if it is Valvoline or Quaker State you are using. The reason is this: the functions of additives blended for specific characteristics can be offset when oils with different additive packages are put together. For optimal performance, it is better to use the same oil throughout.
Myth#5: Synthetic lubricants are not readily available.
Untrue. This may have been the case two decades ago when AMSOIL and Mobil1 were the only real choices, but today nearly every major oil company has added a synthetic product to their lines. This in itself is a testament to the value synthetics offer. But, beware, many of the other "syntheitcs" are not true PAO (Polyalphaolefin) syntheitcs (ie: Castrol Syntec, Penzoil, etc...) they are hydroisomerized petroleum oil or an ester based synthetic blend.
Myth #6: Synthetic lubricants produce sludge
Untrue. In point of fact, synthetic motor oils are more sludge resistant than their petroleum counterparts, resisting the effects of high temperatures and oxidation. In the presence of high temperatures, two things happen. First, an oil's lighter ingredients boil off, making the oil thicker. Second, many of the complex chemicals found naturally in petroleum basestocks begin to react with each other, forming sludges, gums and varnishes. One result is a loss of fluidity at low temperatures, slowing the timely flow of oil to the engine for vital engine protection. Further negative effects of thickened oil include the restriction of oil flow to critical areas, greater wear and loss of fuel economy.
Because of their higher flash points, and their ability to withstand evaporation loss and oxidation, synthetics are much more resistant to sludge development.
Two other causes of sludge - ingested dirt and water dilution - can be a problem in any kind of oil, whether petroleum or synthetic. These are problems with the air filtration system and the cooling system resoectively, not the oil.
Myth #7: Synthetics can't be used with catalytic converters or oxygen sensors.
Untrue. There is no difference between synthetic and petroleum oils in regards to these components. Both synthetic and petroleum oils are similar compounds and neither si damaging to catalytic converters or oxygen sensors.
Myth #8: Synthetics void warranties.
Untrue. No major manufacturer of automobiles specifically bans the use of synthetic lubricants. In point of fact, increasing numbers of high performance cars are arriving on the showroom floors with synthetic motor oils as factory fill.
New vehicle warranties are based upon the use of oils meeting specific API Service Classifications (for example SG/CE). Synthetic lubricants which meet current API Service requirements are perfectly suited for use in any vehicl
