i just bought a truck and need help!
Old Sep 18, 2006 | 11:53 PM
imccall's Avatar
imccall
Default i just bought a truck and need help!
i just bought a 92 d250 with a 5.9 its a 2wd. ive been having problems since i got the truck 2 weeks ago my dad drove it home from work when he got it home and shut it off. it wouldn't start back up,
it'll crank but wont turn over ive tried gas in the throttle body and starter fluid nothing works.a clicking noise is coming from the throttle body and the starter and some fuses under the hood are doing the same. if you could possibly give me some input to what might be going on i would appreciate it -ian
Old Sep 19, 2006 | 02:59 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: i just bought a truck and need help!
If it won't turn over, then either one of the relays to the starter is bad, the starter solenoid is bad, or the starter motor itself is bad. Check and make sure you have juice at the starter. You can also try jumping the starter and bypassing the solenoid.
Old Sep 25, 2006 | 12:49 AM
viper7376's Avatar
viper7376
try to bypass the solenoid if that work ur starter is gone
