Check Engine Code P0441
Old Oct 18, 2006 | 11:45 PM
c0dex's Avatar
c0dex
Default Check Engine Code P0441
I have a 2003 Stratus SXT Sedan and have driven it 2 times since i got it back from the dealership to have the Solenoid Pack in the transmission replaced. The car has driven perfectly the 2 times i have driven it since i got it back and this is the first time the check engine light has ever come on. The Check Engine Code i get is P0441. Any ideas as to what is causing this? Any help is greatly appreciated.
Old Oct 19, 2006 | 08:00 AM
dodgerules86's Avatar
dodgerules86
Default RE: Check Engine Code P0441
Code P0441 is Evaporative Emission Control System Incorrect Purge Flow.
It maybe something as little as a bad hose (for the emissions system), or the purge solenoid itself.
Remember to either reset the computer (typically disconnect the battery for at least 5 minutes) or have the code erased.
Old Oct 25, 2006 | 11:19 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I got that code from not putting the gas cap on after filling the tank, it could also be a bad seal on the gas cap. It's one of them darn emissions thing I ran across on my 03 RAM.
Hope this helps... good luck!
