help please
Old Jul 29, 2004 | 11:17 AM
orionje's Avatar
orionje
Default help please
Hi
I have a 1999 dodge dakota ex cab my question is on my exhuast system before cat and before muffler there are to senor wires that go to computer can they be disconnected so I can put after maket pipes on or is there away to by pass them or is this going to screw up computer I belive they are some kind of heat senors but not sure
Thanks
Steve
Old Jul 29, 2004 | 11:30 AM
uawnick's Avatar
uawnick
Default RE: help please
Nope. Those wires go to the O2 (oxygen sensor). This reads the amount of oxygen in your exhaust gas, in turn tells the engine computer wether to lean out or richen the air to fuel mixture. Not to worry though, as long as you buy an exhaust kit made specifically for your truck you wont have a problem. Should come with adapters and all that junk. Word of advice though, if your not even framiliar with what the oxygen sensors are or what they do you probrably should let a professional to the install. Only because irreversable damage can be done if not done properly. Basically a simple 500 exhaust job can end up costing you 1500 or even $2000... !!
Hope that helped
