Fuel Pump Diagnostic - Dodge Colt Vista
Old Aug 20, 2004 | 03:55 PM
rr66's Avatar
rr66
Default Fuel Pump Diagnostic - Dodge Colt Vista
The book (chilton) shows a fuel pump checker terminal under the hood on the passenger side for this 89 Dodge Colt Vista MPI 2.0 liter that i think has a bad fuel pump. i do not hear any sound when i turn on the key.
I did not open up any lines, but i figure that it will be the pump and wanted to know how the checker terminal works. Does one put 12 volts on it, (that would connect directly to the fuel pump)? Of course, when the pump is off, then one can connect 12 volts to it, but it is in the tank and thus is a lot of work.
Old Aug 21, 2004 | 11:24 PM
rr66's Avatar
rr66
Default RE: Fuel Pump Diagnostic - Dodge Colt Vista
a friend and i fugured it out. we had adjusted the timing by sound, and it was a little off - thus it would not start. the fuel pump is OK.
Old Aug 22, 2004 | 12:21 AM
JCswm's Avatar
JCswm
To answer your question.... that connector supplies battery voltage to the pump so you cant test fuel pressure
Glad it was a simple fix!!!
