AC problems on 97 1500 4x2 ext. cab
Old Aug 23, 2004 | 02:47 AM
GDram's Avatar
GDram
Default AC problems on 97 1500 4x2 ext. cab
Howdy ladies and gentlemen. I recently installed a Flowmaster American Thunder cat-back exhaust system on my 97 Ram 1500 4x2 ext. cab with a little over 53,000 miles on it, and I've noticed that sometimes at highway speed (70-80) my air conditioner stops blowing any air at all. Whenever I lay back off the accelerator, the AC kicks back on. Anybody have any suggestions on what the problem might be?
Old Aug 24, 2004 | 12:05 AM
Ken's Avatar
Ken
Default RE: AC problems on 97 1500 4x2 ext. cab
Next time it happens, reach up and see if the air is coming out of the defrost ducts.
Vacuum-controlled HVAC units revert to defrost (as a safety system) if there is insufficient vacuum to the actuators. If that is the case with yours, you may have a vacuum leak somewhere.
Could be as simple as a cracked hose, or up to a leaking intake plenum pan gasket.
