Help!
Old Feb 26, 2007 | 12:17 PM
stirling_mark's Avatar
stirling_mark
Default Help!
Hey All! i need some help!
My 2000 Dakota would not start yesterday and I cannot get it to fire up. After checking this site i found out how to get the P-codes from the odometer and they are;
P1682 Voltage too low on charging system
P0645 A/C clutch relay open orr shorted, (control cucuit)
P1281 Engine is cold during normal run
P0442 Gas evaporation small leak
P0455 Gas evaporation large leak
I have had some problems recently with the truck starting up hard and idling rough but after it warmed up, it was fine. I called the dealer to see if they would help but they will not. i would have to tow it to them and they would be happy to check it out for about $90.00 not including the tow up.
Please reply with advice on the possible repair...
Thanks
Old Mar 4, 2007 | 10:56 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: Help!
Check temp sensor & temp sensor gauge on the dash, have somebody check the charging system with a scan tool, an autoparts store close to ya should have that for free. Ss for the leaks you are just gona check all the fuel system components. You can use a scan tool on the AC clutch relay but you can just check one of thsoe with a ohmz meter. have fun electrical is a pain in the ****.
