Noise in new 4.7 engine
Old Aug 31, 2004 | 07:09 PM
jimvannatta's Avatar
jimvannatta
Default Noise in new 4.7 engine
Hi everyone. New to this forum. I do have an issue that the dealership just can't put a hand on and hoping someone here might have something to input on this. I have a 2002 with a 4.7 in it, which I hear is practically bullet proof and has had no issues since its arrival in 99. Every morning and afternoon when I start it up I get a knocking from within the bottom side of the engine that lasts anywhere from 15-45secs and then goes away. Anyone out there have any input on this. I have had it in the dealership about 4times and they do not understand where it is or what it is. Have been told wrist pin but they won't be rock solid on that. Looking for any input. Thanks, Jim Vannatta
Old Aug 31, 2004 | 07:35 PM
moparman66's Avatar
moparman66
Default RE: Noise in new 4.7 engine
The only time I had a sound somewhat like yours, the dealer finally narrowed it down to the starter. Changed that and all is well. The first thing I checked was oil pressure. Good luck.
Old Sep 1, 2004 | 01:24 AM
Ken's Avatar
Ken
I drive a 4.7 Dakota, and also happen to be a Jeep technician. 4.7 engines have proven to be quite reliable (I've only been inside about 15 of them since Jeep got them in the 99 WJ).
Mine doesn't make any odd startup noises. It sounds from the description that this only occurs after it sits for a few hours. If so, I'd think about trying a different brand oil filter. I use a K+N, and most of the vehicles I work on have Mopar filters on them. Over on JeepForum, there have been multiple threads about startup noises, many involving Fram filters. I wont start an oil filter debate, but many say that that was their problem. Changing to a different brand got rid of the noise. Suspected issue was a anti-drainback valve that was poorly designed.
Of course, you could have a problem that is much uglier, but the filter is worth a shot.
Old Sep 2, 2004 | 12:52 AM
pershingd's Avatar
pershingd
I'll second the anti-drainback valve issue. I had similar problems with a 97 Neon but I'm not sure which brand I wound up eliminating, but switching to a different brand (no matter which one) is worth a try. Find a good auto parts store that's willing to look it up in the reference book to find one with a drainback valve.
Good Luck
D. Pershing
