Horn started honking on it's own
Old Mar 28, 2007 | 12:12 AM
rdkeisman's Avatar
rdkeisman
Default Horn started honking on it's own
I have an 04 Ram 1500 and after I parked my truck it started honking on it's own over 4 hours later. It started with a few intermittant bursts and after a few minutes it started honking non stop. This truck doesn't have alarms or power door locks. I removed the fuse to stop it, does anyone have any ideas on what it required to repair the problem?
Old Mar 30, 2007 | 01:44 PM
manatlarge2's Avatar
manatlarge2
Default RE: Horn started honking on it's own
I would check the wiring since you said it happended four hours after you were out of it and i don't recommend touching the steering wheel since it has an air bag i would take it to the dealer and have them check out that part of it, the switch might have just went bad for the way you said it started off and them wouldnt shut off till you pulled the fuse.
