Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
heads
Old Oct 14, 2007 | 10:32 AM
alfonsothefons's Avatar
alfonsothefons
Default heads
i have a 71 340 ,80 over with 13-1 piston and running ported x heads withweiand tunnel ram AED750 dp
and want to know if the 99 5.9 magnum heads will interchange
and will the magnum heads give me any performance edge
only reason using the magnum heads is
planning to put motor in my durango and wanted brackets for99 alternator and pulley system to fiton motor
can i use msd 6al and mech distributorand mate itwith the ecu and elimanate factory fuel inj? and timing
and how?
Old Oct 16, 2007 | 08:12 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: heads
Well they are 2 different series of engines Magnum & LA. Im not too sure if they do interchange. Have you looked for aftermarket seprentine belt systems for the LA series engines in general? Because the newer 360 blocks might have different bolt arrangements for pulley systems n such.
Old Oct 16, 2007 | 11:27 PM
alfonsothefons
Default RE: heads
thanks
anybody switch to carb set up and kept the factory ecu for other functions and how?
