Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Vent doors open under load
Old Nov 5, 2007 | 06:24 PM
Headram's Avatar
Headram
Default Vent doors open under load
I have a 1999 Dodge Ram 2500 V-10 4x4 I was on the freeway with the windows up and whenI went to pass I felt air comming from the defrost vent. But the defrost was off.If you have the ac on going up a hill you can hear the blend door shut. SoI checked for vac leaks found nothing. seems to go on under load only.
[IMG]local://upfiles/77203/69B381C87ADB47688AF05BB8B57751F6.jpg[/IMG]
Old Nov 20, 2007 | 08:01 AM
greatdane68's Avatar
greatdane68
Default RE: Vent doors open under load
Chrysler products use a check-valve in the vacuum line that operates your flaps in the airbox. You can get a replacement one at a dealer or parts store for less that ten bucks. That should stop that flap problem.
Old Nov 22, 2007 | 09:07 PM
Headram's Avatar
Headram
will see
Old Nov 22, 2007 | 09:08 PM
Headram's Avatar
Headram
Thank you for the info. I'll see if it works.
