Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Dual Intake 3.0
Old May 21, 2004 | 12:15 AM
Shadowboy's Avatar
Shadowboy
Default Dual Intake 3.0
I was surfing the net last night and came across a shadow 3.0 engine with
two 58mm throttle body's. One on the right and one on the left.
you could see where he had cut the intake (plenum) in half and welded
Another of the same to the other end. It seemed to fit right on in the pics
But i've forgotten where i saw it.(im still looking)
Do you think it would work?
Old May 21, 2004 | 05:29 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Dual Intake 3.0
As long as it has the throttle cables set the same and opening at the same time and rate, then yes. It would also need to be built up quite a bit to require and make use of this much air. Sounds pretty good for a race only application, but not for a daily or street driven car.
Old Oct 16, 2004 | 04:28 AM
casper's Avatar
casper
sounds like overkill to me, my father has a corvette pushing over 600WHP, and only has a 70mm TB. 112mm for a 3.0L sounds useless to me.
