Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
flowmaster mufflers
Old Jul 4, 2004 | 02:02 PM
southpaw70's Avatar
southpaw70
Default flowmaster mufflers
I want to install the 40 series flowmaster muffler on my 2004 dodge reg. cab 4.7 liter. Does anyone know the offset? Or has anyone installed this type of muffler on a new model? I called flowmaster and they dont know the offset? Can anyone help me?
Old Jul 6, 2004 | 12:56 AM
bullitt1229's Avatar
bullitt1229
Default RE: flowmaster mufflers
If you go to Flowmaster's website, don't they have a vehicle search engine which will tell you what mufflers fit your car and the inlet/outlet size and where they are located?
Old Jul 6, 2004 | 01:16 AM
southpaw70's Avatar
southpaw70
I went to flowmaster already and they told me that they didnt know the offset because they never had to work on a new model or installing the 40 series model. Is there anyone out there that has had this work done on a 2004 ram 1500? Or is it the same as a 2003 model? Thanks for telling me!
Old Jul 7, 2004 | 04:00 AM
justasxt's Avatar
justasxt
Should be the same as the '03.
Old Jul 25, 2004 | 04:48 PM
dickbennett's Avatar
dickbennett
I want to put flowmasters on a 97 Ram, but I don't know what series to use, but I want the loudest I can get.
Old Jul 26, 2004 | 06:17 AM
71RoadRunner's Avatar
71RoadRunner
If you want the loudest then you want the regular 40 series Flowmaster mufflers and NOT their 40 series Delta Flow. The Delta Flow series of Flowmaster mufflers is quieter, so you will just want the regular Flowmasters.
Old Oct 16, 2004 | 03:32 AM
casper's Avatar
casper
Loud= straight pipes. If you wanna worry bout emisions
Old Nov 22, 2004 | 02:22 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
If you wan't it loud you should run true duals with an X pipe, no cat, and a pair of 40 series 2 chambers(non DeltaFlow)!!!
Old Jan 5, 2005 | 01:35 PM
cowtnadv's Avatar
cowtnadv
If you want loud try Flowmaster's new Super 40 -
http://www.flowmastermufflers.com/cg...vQn&mv_pc=1409
They do have a kit for the 03/04 Ram -
http://www.flowmastermufflers.com/cg...vQn&mv_pc=1394
The kit is center offset front and dual center offset rear with options to run pipes out straight or on the sides. They are made in the US, and they should have known the offset there you must have talked to a secretary!
Hope that helps.
Old Nov 29, 2006 | 04:12 PM
bvrlvr's Avatar
bvrlvr
i have an 06 4.7 1500 with a Super40, single in single out (in front of the rear tire), it sounds great!!
