Interior Modifications What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
How do I use internal neons?
Old Mar 1, 2004 | 01:14 AM
Jeramy's Avatar
Jeramy
Default How do I use internal neons?
Hey...
I just bought a 2000 Dodge Stratus SE and I plan to put internal neons in the car. I want to put some under the dash and under the seats.
I am really new with doing anything to cars and I would appreciate any help you all can offer. I need to know how to wire everything, what I should buy, and everything.
Thanks for all your help!
-Jeramy
thejreturns@aol.com
God Bless!
Old Apr 12, 2004 | 02:51 PM
72 Monaco's Avatar
72 Monaco
Default RE: How do I use internal neons?
I believe that when you purchase the lights that they come with instructions adn all the hardware required. You should only need a wire cutter/stripper tool. Good luck.
Echo
Old May 31, 2004 | 10:35 PM
356MAGNUM's Avatar
356MAGNUM
Check with local laws too. Some states are **** about it, especially the color choice.
Old Jun 20, 2004 | 05:55 AM
Deleted User's Avatar
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Jul 23, 2004 | 04:03 PM
casper's Avatar
casper
Depending on how you want them to go on, wire them into the parking lights, to a switch, door switch. Mount them where they can't be seen and your done.
Old Jul 29, 2004 | 02:23 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Best advice....leave them off. They are not legal in most areas, and in others it's up to the cop to make the call.....you know what THAT means. If they see them, they are going to figure you fit the "profile" of a drug user/seller...I know I would. Do you REALLY want to know how this ends?[:'(]
Old Aug 4, 2004 | 02:23 AM
KlerricK's Avatar
KlerricK
From my experience and my customer's experience, the police won't bother you if they don't see the bulb.. Excluding underbody kits of course.... [sm=lol.gif]
Old Aug 16, 2004 | 03:26 AM
mikiozen's Avatar
mikiozen
cant you wire them to switches on your dash and turn them on and off as you please... that the best way to avoid cops
plus when you roast a car you can flicker them a lil neon loving ^_^
Old Sep 9, 2004 | 02:07 AM
bearcat74's Avatar
bearcat74
Well after being a dealer in the past (Vortex Auto Restyling) I know that the undercar kits are illegal in almost all places. Vegas is the only place I have run them outside a show or on private property. BLUE AND RED = BIG FINES. This is because they can get you for impersonation of an emergency vehicle acording to the California Vehicle Code. I still run Black Lights in the interior and havent had any problems running them. The best method is to run switches somewhere in the interior to ensure you can turn them off in the situation that you run them where you shouldnt. For most you can run small gauge wire since the draw is low. I would suggest the LED units since they draw milliamps rather than amps, for longer battery life. I have designs and scematics should you feel adventurous and want to build your own. If you have any questions, feel free to post or PM me.
Old Sep 9, 2004 | 02:09 AM
LoNeWuLf's Avatar
LoNeWuLf
they have lights u plug into ur cigarette lighter too...
