Interior Modifications What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
how to remove door panel for new speakers
Old Dec 28, 2005 | 02:41 AM
Jaime340's Avatar
Jaime340
Default how to remove door panel for new speakers
im looking to remove the door panel to install new speakers, also how about the front dash speakers does anyone know the size to eather one. or how about the stock amp is it in the stereo itself or mounted somewere els? any reply would help thanks. o, yea magnum rt boston acustic 6 disc cd system thanx
Old Jul 8, 2006 | 04:27 PM
SemiHemi's Avatar
SemiHemi
Default RE: how to remove door panel for new speakers
ORIGINAL: Jaime340
First what vehicle?? That is what i dislike about the global interior/exterior/audio forums, need to have each car section a seperate forum.
Now back to your ?, if it is a Magnum/300 then the BA have 6.5" @ 2 ohms. There are a few companies that are making 2 ohm replacements now. BA is one I think.
The amp in the magnum is under the driver dash next to the steering column.
Old Oct 12, 2006 | 02:14 AM
ram_tough's Avatar
ram_tough
I have the same problem with a 1992 Dodge Ram 150 on the front speakers. I thing you have to replace all the door moulding pins? Not sure. I could use some help too!
