Interior Modifications What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Sliding window locks
Old Jan 28, 2006 | 12:03 AM
52b3b108's Avatar
52b3b108
Default Sliding window locks
I don't know if this is an interior or exterior question, but are there special locks you can use for the sliding back window in my truck? I've heard that they're reasonably easy to get into and would want to check out a lock if there are any out there. The accesory sites I've looked at don't have any. Thanks.
Old Feb 9, 2006 | 08:45 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Sliding window locks
You might check this guy out.....
Dusty
http://www.v-capital.com/14techtrans...ent.cfm?ID=235
Old Mar 28, 2006 | 11:35 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I know this is cheasy/cheap and all the above, but, you could use those window locks for homes...do you know what I'm talking about? It slides right onto the outer lip/rail thing and then you tighten it down kind of like a wing nut type screw.
I only say that because I had some of them and used them to hold the window open during the spring and it worked very well. It could be used as a temp fix until you find a real lock
Just in case you haven't found a solution yet.
