Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Jeep Grand Cherokee diff/trans issues?
Old Sep 8, 2004 | 04:58 AM
NeverSatisfied's Avatar
NeverSatisfied
Default Jeep Grand Cherokee diff/trans issues?
Hey fellas, I may get a 93-98 Jeep Grand Cherokee and I have a few questions about the diffs and trans:
Do the front or rear diffs fail often if daily driven, not towed with much, and not off-roaded, with either engine?
Do the Dana 35c rear ends break more than the Dana 44al rear ends or enough to merit buying a 96+ with the 44al [all 96+ V8 have them]
Do the 44RH/44RE [5.2] transmissions fail often and which is more reliable?
thanks alot!
Sean
Old Nov 30, 2004 | 09:16 PM
brian_a_mcmillen's Avatar
brian_a_mcmillen
Default RE: Jeep Grand Cherokee diff/trans issues?
Geeeze...I think the answer is "it depends." I have a cherokee sport with 162,000 miles on it and have only had to replace the u-joints in the front axle once. I do take it off road once in a while but stick mostly to the street. These hole up as well or better than everything else.
Brian
Old Dec 13, 2004 | 04:36 AM
laphan's Avatar
laphan
Transmission:
Cherokee (XJ) uses a way better transmission; it has AW-4 (Aisin Warner) which is famous to last good over to 200K miles with proper maintainance and care.
Grand cherokee uses a really weak chrysler transmission (96-98 ZJ has 42RE/A500 for 6 cyl and 44RE/A516 for 8 cyl). 42RE and 44RE is basically the same design but 44RE is a little stronger (more clutch packs to hold higher torque from V8 engine). 44Re and 44RH are the same transmission, the difference is RE = computer controlled and RH = hydraulic control (they swithed from 44RH to 44RE in 96 model).
From my experience, 1998 42/44 RE has problem with drum seal leaking (happened to me at 70K miles). Once it leaks, transmission will slip and its a rebuild time.
Axle:
Dana 44 AL is weak and often have problem with the bearings (3 out of 5 V8 Jeeps that I tested have whining noise from bad bearings). All V8 from 96-98 have D44AL.
Dana 35C (all 96-98 6 cyl has D35C) is weaker in the shaft but less bearing problems; you can easily break it if you do some hardcore offroading or put a bigger tires there.
Speaking from my experience; open a vehicle repair account or buy an extended warranty if you happen to get a ZJ. It breaks often and expensive to fix.
Old Dec 17, 2004 | 02:09 AM
casper's Avatar
casper
I had an 87 Cherokee pioneer with almost 300,000 on it when I sold it still running. It had its noises, but the 4X4 still worked and the motor and trans were strong, I am not sure what trans was in it, but the inline 6 is almost bulletproof.
Old Dec 17, 2004 | 02:57 AM
laphan's Avatar
laphan
casper, you have AW4 tranny. All cherokee has AW4. I heard that AW4 is developed and used by Toyota for their trucks (doesn't susprise me if its really strong and reliable).
You must take a good care of it (300K on the tranny is pretty normal if you really take a good care of it). My friend has 385K on his 88 cherokee and it has original engine/tranny.
