Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
93 Grand Cherokee Limited
Old Jun 8, 2007 | 11:02 AM
dishdude2k's Avatar
dishdude2k
Default 93 Grand Cherokee Limited
hello all.. i have and oldie... but good truck.. just a few problems.. i have a 93 grand cherokee limited.. 5.2 mpi all time 4x4 .. question is this.. if i have to turn the jeep.. and turn the wheel all the way.. it seems to bind.. one tire will actually slide and not turn like its supposed too.. it does it no matter whether i turn right or left.. and does it worse if im backing up.. and i mean alot worse.. also.. when i hit the brakes.. they squeel.. and it feels like my rotors are warped.. i checked them.. and they look fine.. pads look fine.. could it be i have a messed cv axle? maybe moving? hence the loud brakes.. and the hopping.. ? any input would be great.. thanks in advance...
Old Aug 10, 2007 | 05:19 PM
steve05ram360's Avatar
steve05ram360
Default RE: 93 Grand Cherokee Limited
do you still need help on this? sounds like your t-case is not splitting the power like it should...
Old Aug 12, 2007 | 07:32 PM
horatio102's Avatar
horatio102
If you haven't figured it out yet, that's your center differential's viscous coupling that has failed.
