Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Cooling Fan!!
Old Jun 28, 2007 | 11:42 PM
tay_ang's Avatar
tay_ang
Default Cooling Fan!!
I went out mud bogging the other day and my jeep overheated and i noticed than my cooling fan was not kicking in when it should have. i tested the fan and the fan works fine can anybody give me any suggestions??
Thank you
Old Jun 28, 2007 | 11:43 PM
tay_ang's Avatar
tay_ang
Default RE: Cooling Fan!!
sorry its a 97 jeep cherokee sport
Old Aug 29, 2007 | 07:34 AM
jdb1937's Avatar
jdb1937
Cooling an engine, particularly when you are "mud bogging" is going to require more than what is stock. You are looking at a 160 degree stat (run 180 water temperature) and i would put in the largest aluminum radiator that will fit. Then add a flex a lite electric fan, ditch the stock fan. Then do something with the water pump if you can (ask flowcooler) and then end of cooling problems. Also, if you have a/c - mount fans in front of the a/c condensor as "pushers".
Old Sep 3, 2007 | 11:58 PM
steve05ram360's Avatar
steve05ram360
a 160 deg t-stat will toss a code... stick with a 180 t-stat. adding the pusher fan in front would also help.
