Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
carb swap
Old Aug 25, 2007 | 09:06 AM
browncityredneck's Avatar
browncityredneck
Default carb swap
hello everyone-new to this forum-i recently picked up a 1986 wagoneer(woody) and am looking to restore it first issue is motor-ive heard that the 2.8l v6 can be swapped out w/ the 3.4 or is it 3.8 v6 from the camaros;anyone know if this is true?also until i do swap motors can i use an adapter plate and go from 2 to 4bbl?this is gonna be a long project as it needs a ton of body work so if anyone knows of parts out there please let me know---thanx in advance
Old Aug 26, 2007 | 11:12 AM
speedyshelby's Avatar
speedyshelby
Default RE: carb swap
http://www.lunghd.com/Tech_Articles/...Project_XJ.htm
Should be all you need to know. You can use an adapter it just not going to be the most powerful or best setup.
Old Aug 28, 2007 | 02:27 AM
ILLXJ's Avatar
ILLXJ
Check over at www.NAXJA.org & search for 3.4 swap. A few people have done it & if I remember correctly there is at least 1 write up on it. JIM.
