Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
95 Jeep Grand Cherokee Limited
Old Sep 11, 2007 | 07:11 AM
318dodge's Avatar
318dodge
Default 95 Jeep Grand Cherokee Limited
Hello
I have a 1995 jeep grand cherokee limited, with the 5.2 in it. I have had to replace the thermostat once a year for the last two years and I am going to have to again this month. It always happens around the same time each year. I always put a thermostat right from the dealer in.
I was just wondering if this problem is common or if there is something else I should look for?
Thanks for all the help.
Old Sep 12, 2007 | 11:31 PM
steve05ram360's Avatar
steve05ram360
Default RE: 95 Jeep Grand Cherokee Limited
welcome to DF...
no it's not common, go to Napa and get one from them. Drill a very small air bleed hole in the diaphram before installing it. I've put 200k on the magnum motors and have yet to have a t-stat fail on me. another thing to consider is when you swap it out, flush the motor before you do the install. make sure you use distilled water on the re-fill. this prevents sludge from building on the inside of the motor/radiator.
