Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
2006 Commander Stalling
Old Oct 16, 2007 | 08:42 PM
RedRocker's Avatar
RedRocker
Default 2006 Commander Stalling
My 06 Commander Limited 4x4 stalls at low speeds with no warnings. Its happened probably 10 - 12 times over the past 6 months. The dealer says its not throwing any codes, and they cantduplicate the problem. If you do a google search with "jeep commander stalls", you will get over 55,000 results. Of course I havnt read all of them, but just the first page clearly shows that this is a real problem. I found articles on www.comsumeraffairs.com, NHTSA investigations, and countless threads on other forums of several people experiencing the same problem. I consider this a serious safety issue and would think DaimlerChrysler would put high priority on correcting this issue ASAP. Anyone else having this same problem? or had any luck correcting it?
Old Nov 8, 2007 | 11:56 PM
mtngoatbb's Avatar
mtngoatbb
Default RE: 2006 Commander Stalling
crank sensor, cam sensor, wiring issue, pcm, etc, etc you really do ned a code to set unless you just wanna throw darts...
