Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Transmission question
Old Feb 20, 2009 | 02:52 PM
fireman2828's Avatar
fireman2828
Default Transmission question
My friend at work has a 98 wrangler 4.0 automatic. When it is cold and she leaves the parking lot, trans. dropes out of gear for a few seconds then back in. It does it a couple times until it warms up. It doesn't alway do it, just when it is colder out. Any advise on this would be appreciated. Thanks....
Old Feb 20, 2009 | 11:46 PM
transguy37's Avatar
transguy37
When it drops out of gear, does the engine rev up? How cold is it there?
Old Feb 21, 2009 | 08:23 PM
fireman2828
she says it revs up, then will go back in. Usually happens under about 30 degrees or colder. usually colder.
Old Feb 21, 2009 | 08:30 PM
transguy37's Avatar
transguy37
Ok, that's not really that cold. She has the Toyota trans AW4, there should be a cable coming up from the trans to the throttle body. This cable controls line pressure rise in the trans. You can try to adjust the cable so that it pull on it tighter, this will raise line pressure and may help with the flared shifts. To make it tighter, it has a nut on each side of the bracket it is connected to, should be either a 12mm or 14mm nut. Adjust the cable so that it is moving away from the throttle body, this will tighten up on it. Hope this helps.
Old Feb 22, 2009 | 10:55 PM
fireman2828
How tight do you tighten it? Can it be over tightend? Just don't want to ruin anything.. Thanks for your help, it is appreciated...
Old Mar 5, 2009 | 12:36 AM
jeffturner's Avatar
jeffturner
Default Hey
What advice exactly you looking for?
Old Mar 6, 2009 | 09:44 PM
transguy37's Avatar
transguy37
Sorry, been very busy. You can get it too tight, but it won't hurt anything. You will know if you have it too tight because it will engage hard when you put it in drive or reverse.
