LED replacement bulbs for fog lights
I have a brand new 97' Jeep Grand Cherokee Laredo. OK, new to me. I am going through the systems doing maintenance and the like and want to replace the somewhat weak fog light lamps to LEDs that are brighter and draw less power.
Has anyone has success with LEDs or replace the plastic lens with glass and install halogens? Thanks ~E :icon_steer: |
Originally Posted by SirZog
(Post 2968962)
Has anyone has success with LEDs or replace the plastic lens with glass and install halogens? Thanks ~E :icon_steer: A brighter individual light source, like a halogen bulb, is easier to work with if you plan on modifying an OEM assembly. Here, you can often get a kit that will include the bulb mounts as an integral part of the reflector - this ensures the bulb is positioned properly to get the proper pattern. If you don't change the lens, you'll have brighter lights but not an optimal pattern. I recommend buying a quality assembly - complete, ready to "bolt on". Also, I wouldn't worry about the power savings, a jeep is a gas guzzler regardless of the electrical power savings. If you really want to improve your performance a bit as well as save on your fuel cost a bit, I'd recommend changing the mechanical cooling fan to an electric one. I like the 2 speed Ford Taurus variety, but one isn't for everyone either - the control system needs to be able to handle high in-rush current to start it up. |
