Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
04 grand cherokee (4wd problems)
Old Dec 20, 2005 | 12:20 AM
Dakotahub's Avatar
Dakotahub
Default 04 grand cherokee (4wd problems)
04 Grand Cherokee. I'm having a hard time getting it into 4wd. The shifter will go in easy enough but it won’t engage. I've stopped...put it in reverse..tried everything. Tried it in part time and full time. It will go in eventually but I can't imagine it should be this hard.
Any ideas before I bring it to the shop. (I'm sure I'll get the "It's working fine" speech from the dealer)
Old Feb 3, 2006 | 12:20 AM
Overland1's Avatar
Overland1
Default RE: 04 grand cherokee (4wd problems)
Which transfer case (SelecTrac, QuadraTrac, or QuadraDrive)?
Either way, to shift into 4WD/low range, the transmission should be in neutral and the vehicle moving very slowly (if you have SelecTrac).
Old Feb 16, 2006 | 12:33 AM
Ken's Avatar
Ken
The "selectrac" system is incredibly finicky. The biggest problem with getting them in and out of 4wd has to do with the tires. Different rolling circumferences of the front and rear tires cause the driveshafts to rotate at different speeds. The shift fork wont engage until everything lines up perfectly. This may have nothing to do with different "sized" tires. It is often caused by different levels of wear between front and rear. If you aren't rotating your tires at least every 7500 miles, the fronts will feather and wear excessively on the outer edges. Tire pressure is impotant, too.
Even when everything is as good as it can be, the 242 case is finicky.
