Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Lasfit Wrangler JL 2018-2022 Switch Panel Bank - Best Jeep OEM Switch Design Ever!
Old Sep 11, 2023 | 09:16 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default Lasfit Wrangler JL 2018-2022 Switch Panel Bank - Best Jeep OEM Switch Design Ever!
Preparing for a trail always requires us to install a couple pieces of additional equipment in order for us to get more remote in a safe and enjoyable manner. One of those items is an auxiliary switch panel that's gonna allow us to run electronic accessories on demand like off-road lights or an air compressor. Unless you had it installed from the factory or when you purchased your vehicle it's now a pricey option to do after. The installation makes that price tag just north of a thousand dollars making outside of the price range and not feasible for us to do.
Now, Be your own home mechanic with our switches! Our switch banks DON'T require any software updates, just install and is ready for use. You don't need to go to the dealership to activate it. A premium but economical solution to run 4+ auxiliary switch panels without having the hassle of getting your ecu flash is what we want to provide you with.
Some main features of our switch bank that you might be interested in:
UNIQUE BUTTON DESIGN
We produced a classic yet unique OEM design after considering over different needs that you might have. The two buttons on the left side of the red switch can not only control the front and rear differential locks like the factory switch. It can be also set as switches to control other lights and devices. With that being said, you can control up to 8 devices with our full kit .
The Front & Rear Locker Switch Works in 2 Modes
* Default: Locker Mode
(Only operated when your Jeep is in 4L)
* Standalone Mode
(F&R work independently as a normal on/off switch)
NO SOFTWARE UPDATE REQUIRED
You don't need to go to the dealership to activate it after installation. Just install with our installation guide and is ready for use.
RJ45 JACK ON THE RED SWITCH
The RJ45 jack is an inline coupler for compatible CB radio, fully ready for off-road/overland trail use!
WATERPROOF RELAY FUSE BOX WITH NEAT WIRES
Each fuse box features four high-quality relays and 4x40A fuses.
The package will come with a full kit that includes everything you needed for installation.
You can get more information about Lasfit Jeep Wrangler JL 2018-2023 Auxiliary Switch Panel Bank Kit from this page: http://www.lasfit.com/products/jeep-...ary-switch-kit
