Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
2019-2023 Jeep Gladiator LED Upgrade Bulb Size Guide
Old Jan 10, 2024 | 08:26 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default 2019-2023 Jeep Gladiator LED Upgrade Bulb Size Guide
Lasfit offers compatible bulb upgrade options for Jeep owners. If you have factory halogen bulbs, we have the LSplus H13 LED bulbs that can provide you with an ultimate brightness experience. Additionally, our switchback LDplus fog lights offer 6000K bright white and 3000K amber yellow options. We also have turn signal bulbs suitable for the Jeep Gladiator CK socket, providing an upgrade solution for your turn signals. Follow our footsteps to unlock more LED bulb options offered by Lasfit for the Jeep Gladiator.
Bulb Size
Low&High Beam: H13 (If equipped with Halogen Headlight Bulb)
Fog Light: 5202
Front Turn Signal Light: 7440/7443
Rear Turn Signal /Brake/Tail Light: 7440/7443
Backup Light: 921
Dome Light:168
Compatible LED bulbs for 2019-2023 Jeep Gladiator
Low&High Beam Bulbs: LSplusH13
Lasfit will be launching the all-new upgraded LSplus H13 LED bulbs in 2024. With a power output of 65W and brightness of 6500LM, it represents Lasfit's brightest series of products to date. The external driver helps to prevent excessive heat buildup within the headlights, while the newly upgraded double copper tube and copper substrate efficiently dissipate heat. The 30mm ball bearing fan and built-in finned heat sink ensure timely heat dissipation. With significant improvements in heat dissipation, the headlights offer increased stability and durability, thereby extending their lifespan. Smaller fan, higher efficiency!
Note: The previous version of Lasfit's LSplus series has been sold out, and the upgraded 2024 version is coming soon! We will provide exclusive discounts for vehicle owners to test these upgraded versions!
Fog Lights: LDplus5202
White? Amber? All you can get with one bulb from Lasfit LDplus series LED light! The bright white light of 6000K escorts you for driving at night, and the amber-yellow light of 3000K provides you with safe driving through rain, fog, and snow weather. The external driver does not hinder the installation of the fog lamp assembly, and the 360° adjustable socket easily realizes the self-adjustment of the light beam.
Front Turn Signal Lights: T-7443D-CK
For the T-7443D-CK, Gladiator owners can enjoy a configuration of 24W and 2400LM, providing ample brightness for various lighting need and ensuring enhanced visibility and effectively alerting pedestrians when the turn signal is activated. These bulbs are equipped with a convenient switchback function, providing you with both Amber and White lighting options. The 6000K white lights can be used for parking lights or daytime running lights, while the 3000K flash amber option is perfect for turn signal lights.
Rear Turn Signal /Brake/Tail Lights: T3-7443R
We just have upgraded 7443 LED bulbs for Gladiator' rear turn signals. With 24W and 2000LM brightness, they ensure the vehicle behind you easily notices your change in direction. The upgraded canbus system and straightforward installation make it a simple plug-and-play experience. The T3 series LED bulbs feature 8 heat emission holes and a heat filter, allowing efficient heat dissipation during operation. Safety protection ensures stability and durability for a reliable performance.
Backup Lights: T-T15
Lasfit T-T15 can provide 1500LM,6000K bright white for your Gladiator, non-polarity design, and have a similar size as factory backup bulbs can let you put the aftermarket LED bulbs into the housing without any effort.
Dome Lights: L-T10
The L-T10 series features 3 bright 3030 chips that can provide 800LM of brightness for you. With its 6000K white light, it can effectively illuminate the interior of your Gladiator. The 360°lighting effect ensures that no area is left in darkness, providing ample lighting for you.
Customer Feedback
Case1
I’ve ran Lasfit in every car I’ve owned since 2017. Just like the rest, this combo kit for my Gladiator is perfect. I did have to find an alternative solution to the drl’s BUT everything else is perfect as always. Great light output, great customer service and the products are always top notch. Will be picking up the pod lights and mounts shortly.---M.c.
Case2
I replaced the factory halogen headlights and fog lights on my sport s gladiator. Awesome upgrade and super bright! The fog lights can change from white to yellow which is pretty cool depending on the look you are going for. You can see the before and after in my photos. Took me about 2 hours but I had no idea what I was doing and had to watch some videos lol. All in all it was easy.---R.B.
Case3
Love the lights, cant believe I waited this long, if you have the factory halogens just do it great upgrade worth the money.---a.r.
illuminate the road ahead with Lasfit's LED bulbs. Don't miss out on this opportunity to enhance your driving experience. Shop now and see the difference!
