Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
TC Problems
Old Jul 9, 2004 | 12:46 AM
swany6mm's Avatar
swany6mm
Default TC Problems
Ok, first, what I'm working with:
'86 2dr Jeep Cherokee (Pioneer) with Selec-Trac (vacuum switch on the consol to switch between 2WD and 4WD), 3spd Auto (904?), 2.8L
Ok, first question. I finally got the trasnfer case some what working again. When I stop, put the auto in nuetral, switch from 4H to N or 4L, all's good. I can drop the auto in drive or reverse (wow, what a jolt when it engages *lol*). Now, when I stop, put the tranny back in neutral, then go from 4L to N, then try and go back into 4H or 4L, it grinds. I have to actually slam it quickly into either 4H or 4L. That can't be good for the transfer case. This isn't normal, correct?
Second question.
The inital problem was that I couldn't get it to switch into 4WD at all. I would flip the switch, but it would never engage. Turns out, the problem was the vaccum pot(motor) was slightly bent, so the rod couldn't move. Well, I went ahead and actually took the pot completly apart (wasn't easy), fixed the rod as best I could, and put it back together. Problem is, I couldnt' get a good enough seal, so it's kind of hit or miss if it can pull/push enough to engage/disengage the TC. I'm going to have to actually replace it. My local yard only has Jeeps that are all manually run. Would a dealership still have these parts you think? Or, does anyone know who sells replacement parts for a jeep this old? Or, if it turns out I would just be better off ditching that TC, can I use any TC and have it bolt right back up, or am I limited in what I can put in there? I really would rather not repalce it, but I'll do what I have to do.
Sorry this is so long winded. Thanks for any help anyone can give
Swany6mm
