Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Fault Code 43 Jeep
Old Feb 27, 2007 | 01:53 AM
pcjeep's Avatar
pcjeep
Default Fault Code 43 Jeep
Hi Guys,
I found I had a fault 43 -Ignition coil driver circuit.
Do these have problems with the coil to pcm wiring?
I already replaced the coil, and the pickup coil, and crank sensor.
I think I may try to replace the whole distributor assembly next.
1997 grand cherokee 4.0 2wd:
Old Mar 30, 2007 | 04:11 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: Fault Code 43 Jeep
9 times out of 10 that i have run into that has been a PCM
