K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
1988 Aires won't start HELP!!!
Old May 16, 2007 | 06:50 PM
hankie's Avatar
hankie
Default 1988 Aires won't start HELP!!!
Was stored for 1 year, put in gas stablizer. Went to start today, wouldn't start on it's own. Sprayed in starter fluid& it would start, but not continue to run. Tried gas into carb. & start, but not run. Doesn't seem to be getting gas into carb. any help?
Thank you.
Old May 18, 2007 | 09:45 AM
gearhead71's Avatar
gearhead71
Default RE: 1988 Aires won't start HELP!!!
You might want to start by disconnecting the fuel line at the carb, put the line in a coffee can and have some one turn over the engine and look a what comes out the line, if nothing comes out Id start with the fuel pump,while the line is still un hooked take an air compressor and give a couple quick puffs of air in it, if there is a blockage this should dislodge it. After you get it running you might want try putting a product called " Sea-Foam" its a gas additive that cleans the fuel lines and carb/injectors.Put it inthe tank then fill it, let it run and eventually it should smooth out and run fine. Ive used it with a lot of success Even my 87 Aries coupe that was sittng in a garage for a little over a year started running better after putting it in the tank.
Old May 18, 2007 | 06:50 PM
hankie's Avatar
hankie
After I unhooked and tried to strart there seems to be some gas coming through the one line I unhooked. I tried putting an additive into gas - didn't do anything. Now I'm going to try spraying some carb. cleaner in. I'll see what that does. Thanks for the ideas.
