K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
93 Dynasty Rear Door Paneling
Old Jan 20, 2004 | 02:12 AM
neville07's Avatar
neville07
Default 93 Dynasty Rear Door Paneling
Can anyone tell me how to get this paneling off the door? My window popped off the track and i want to try and get it back on. I removed the 2 screws at the bottom of the door, worked off the left side, and the top side is almost off ( where the door lock is) The right side is being a bitch seems like i might've missed something. Do I have to remove any of the wood trim? I tried removing the upper wood trim, seems like once it's in.... it's in! Any help would be appreciated. I can get a picture of the door if that would help anyone help me.
Old Jan 20, 2004 | 04:00 AM
71RoadRunner's Avatar
71RoadRunner
Most door panels are held on by push in clips. Is the door handle in the way or holding it on perhaps?
Old Feb 6, 2004 | 04:30 PM
GTCandGTSturbo's Avatar
GTCandGTSturbo
Default RE: 93 Dynasty Rear Door Paneling
After you remove all the screws, pull at the bottom and it will pivot at the top. Once you are assured all you fasteners are clear, you have to push up to clear the tabs that it slides down into on the top.
